NEC 27" TV Yoke Needed
Discussion in 'Electronic Repair' started by Shoreline Electronics, Nov 12, 2003.
  1. Make : NEC
    Model : CT2750A
    Set has strange convergence issues.....yoke has to be bad!
    Does anyone have a junker to pull a yoke from. The number on this one is
    48007363 but I would think most any of the NEC 27" CRT yokes will do.
    Thanks for checking!
    Jeff Stielau
    Shoreline Electronics Repair
    344 East Main Street
    Clinton,CT 06413
    860-399-1861
    860-664-3535 (fax)
    "If you push something hard enough it will fall over."
    Fudd's First Law of Opposition - Sir Sidney Fudd
  2. John Del
    John Del Guest
    Subject: NEC 27" TV Yoke Needed
    It's definitely the yoke. The problem with a pull is that it might not survive
    the shipping. The problem as I understand it is that the convergence shunts
    inside the yoke housing are mounted in a mastic goo that dries up over the
    years, and the shunts shift. IIRC, NAP yokes would sub into these NECs, but
    I'm not positive.
    John Del
    Wolcott, CT
    "Nothing is so opportune for tyrants as a people tired of its liberty."
    Alan Keyes
    (remove S for email reply)
  3. It kinda looked like a NAP yoke.......I will investigate!
    Thanks for the info John....
    Jeff Stielau
    Clinton,CT 06413
    860-399-1861
    860-664-3535 (fax)
