NEC 21C-09TNZ CTV
Discussion in 'Electronic Repair' started by Kieran, Nov 14, 2004.
  1. Kieran
    Kieran Guest
    Hi Guys, not a fault really, just something that has bugged me for a
    long time. When you change channel, the OSD shows channel no & time.
    How the heck do you adjust the time? I've tried every combination of
    button presses I can think of to no avail. Obviously I don't have an
    owners manual.
  2. Jerry G.
    Jerry G. Guest
    I cannot locate that model number anywhere! For sure with all of these TV
    sets you will require the original remote control. The universal ones will
    not give access to the internal user set-up menus. The front panel controls
    on most TV models, especially in sets that are newer than about 10 years, do
    not give any menu access.
    On the original remote, you may have a direct access to the time, or you
    must press the Menu or Set-up button. From there you must read the prompts,
    and there should be one for TIME or TIME Set.
  3. James Sweet
    James Sweet Guest
    I hate that, how hard could it be to make all functions accessible from the
    front panel controls? Even if you had to go through some cumbersome menu to
    do it, at least then the set would be useable. I never have found a remote
    to adjust the brightness on my Sony XBR, they just *had* to make it
    different than all the common Sony's.
  4. Kieran
    Kieran Guest
    I wish that life was that simple! I do have the original Remote
    Control, & sadly apart from a myriad of buttons for TV, VCR & Teletext
    functions there are none for set up menus or time functions. Tuning on
    this set is achieved via front panel controls. Picture & sound
    controls are on the RC & duplicated on the front panel. Sometimes
    wonder whether the TV clock is supposed to get its info from the
    Teletext signal, just a thought. Oh for an Owners Manual!!
