Sirs,
Can anyone guide me as to how should I rectify the fault and make its radio section operational.
I can tell you that the radio section used the following ICs and I have already downloaded and have the datasheet. What i need is the functionality of the whole operations of selector mode switch, which is only possible with complete schematic.
The Circuit uses the following ICs in radio section:
LA 1185 + LA1260
BA 1332
Main AF Amplifier built around BA5406
I am confused whether the selector switch (Radio/Tape/Sleep) or band switch (FM/MW/SW1/SW2) has gone bad. What are the tips whereby I should reach at a conclusion about rectification.
Thanks and regards,
Shamim_India.
LA 1185 + LA1260
BA 1332
Thanks and regards,
Shamim_India.
