NASA Depth sounder help
Discussion in 'Boat Electronics' started by Mark, Jul 21, 2003.
  1. Mark
    Mark Guest
    Can someone provide me with some instructions for the use of my NASA Target
    Depth Sounder.
    There are only 3 buttons, but, I have been unable to deduce how to set the
    alarms. Are there any other features are avauilable besides max/min depth
    alarms.
    Thanks in advance - Mark
  2. WaIIy
    WaIIy Guest
    Briefly, to set keel offset, press set before turning on power, use
    alarm up
    and alarm down to set desired value. complete by pressing set.
    each time the unit is switched on, the offset value is displayed for a
    few
    seconds.
    to set alarms...
    press alarm up (down) all it says is enter the new value and accept by
    pressing set.
    To enable alarms, press alarm up and down at the same time. an "A" will
    display briefly to show that alarms are set. Same to disable
  3. Mark
    Mark Guest
    Thanks for the info.
    Mark
  4. ruddorthner
    ruddorthner
    3
    Sep 9, 2009
    I have a NASA target depth sounder. It has three buttons Set, Alarm up and Alarm down. I have set my depth by switching the unit on with set depressed but I find that a depth is being displayed, but there is also an "E" displayed. What does this mean? is it E for Error. The depth does seam to give a representative depth, but when I run my engine the value becomes erratic, however when I switch the cabin lines and nav light on the depth settles.
  5. ruddorthner
    ruddorthner
    3
    Sep 9, 2009
    NASA Marine's answer
    NASA Marine's answers is:
    E stands for Echo and not error. If unit ok with engine off then it must be noise from alternator - supress with supressor as you would to stop an allternator noise on your car radio.
