James Sweet
Thanks to help from this group I finally got this 41JP20 which I picked up
for free finished. Took a while since it's out at my mom's and I could only
tinker with it when I had time to go out there.
Initially the set was dead, replaced HOT, chopper in the power supply and
the fuse, got it up and running
CRT coolant was contaminated, removed, cleaned out and refilled all three
CRT assemblies, tweaked convergence a bit, was working reasonably well
Flyback blew up, set is again dead
Replaced FBT with HR Diemen replacement, set worked briefly and then begin
shutting down
Tweaked HV shutdown pot, adjusted B+ and HV to spec
That restored operation, then finally tonight I went through the service
sheet that came in a pouch on the back of the set (why can't every set have
that?) and adjusted optical and electrical focus, color ballance, gray
scale, black level, geometry and a full convergence alignment. Despite the
old age of the set the picture looks fantastic, it's bright and reasonably
sharp with good color. I'm sure it'll get several more years of use.
shutting down
