nano coils
Discussion in 'Twilight Zone' started by plasmaniac, Oct 19, 2018.
Thread Status:
Not open for further replies.
  1. plasmaniac
    plasmaniac
    Oct 19, 2018
    Using a straight wire of .01 mm dia. and wrapping it with .001mm wire to create an auto transformer, how can I calculate the peak voltage output per kilometer of primary wire? Using 100vdc primary supply at fully charged coil. VLF.
  2. hevans1944
    hevans1944 Hop - AC8NS
    4,615
    2,154
    Jun 21, 2012
    Your post MNFS. Go troll somewhere else.
    OBW0549 likes this.
  3. BobK
    7,682
    1,688
    Using DC, 0V.
  4. Harald Kapp
    11,649
    2,692
    @plasmaniac : Whatever you're trying to achieve: with that little and useless information you're not going to get useful feedback. The thickness of the wire has nothing to do with the output voltage of a (auto or not) transformer under no load. With load, the limited thickness of the wire creates resistance which will reduce the output voltage. You have not given any value for the expected load :(
    Wrapping a straight wire with another wire does not create a transformer. What we understand when we read wire is typically a copper wire which, being not magnetic, does not lend itself to the construction of a transformer's core. A transformer's core needs to be magnetic to concentrate the magnetic flux.
    As @BobK stated: No transformer will generate an output from a DC input.
  5. plasmaniac
    plasmaniac
    Oct 19, 2018
    Without a non disclosure agreement my intentions must remain, in your words, useless info. Good to know that you "smart" guys have no idea where I am going. Consider my question answered.
Similar Threads
Loading...
Thread Status:
