N25D solder iron compatible tips (also seeking)
Discussion in 'Hobby Electronics' started by Jim, Mar 30, 2009.
  1. Jim
    Jim Guest
    The datasheet for the N25D says that the NT1 tip is suited for the N25D.
    Looking at the image of the tip, it in no way resembles that presently
    in either of my N25Ds.
    The first one that I bought has a screw plate holding the pencil in, the
    second has a nut. On top of that, the first one is a threaded barrel
    for the tip, whilst the other has a philips screw holding the tip in place.
    Neither of these resemble that description, nor the tech drawings for
    the NT1 which appears to be a complete set - both the pencil and the tip.
    The iron's datasheet: http://www.farnell.com/datasheets/42272.pdf
    The tip's datasheet: http://www.farnell.com/datasheets/19755.pdf
  2. Jim
    Jim Guest
    Farnell got make to me this morning, the NT1 tip is held by a screw in
    the pencil.
