n-channel MOSFET common source amplifier
Discussion in 'Electronics Homework Help' started by studentLab, Apr 23, 2014.
  1. studentLab
    studentLab
    11
    Apr 21, 2014
    Hello and good day for all, I need advice in finding Vout and ac voltage gain in n-channel MOSFET common source amplifier.
    [​IMG]
    Here i get :
    Since the source is grounded, the gate-to-source voltage is
    VGS = (R2 / (R1 + R2)) x Vdd
    VGS = (33k / (51k + 33k)) x 15
    VGS = 5.893V
    ID = k [ VGS – VGS(th) ]2
    Since: VGS = 7.5V, VGS(th) = 5V, ID = 5mA
    Therefore : ID = k [ VGS – VGS(th) ]2
    k = ID / [ VGS – VGS(th) ]2
    k = 5mA / [7.5V - 5V]2
    k = 0.8mAV-2
    The Drain Current ID at VGS = 5.89V is ID = 0.8mAV-2 [ 5.89V – 5V ]2
    ID = 0.634mA
    The Drain Voltage is VD = VDS = 15V – [0.634mA x 3.3k]
    VDs = 12.90V
    The Drain to source resistor is rDS = VDS / ID
    rDS = 12.90V / 0.634mA
    rDS = 20.35k
    Rin = R1||R2
    Rin = 51k x 33k / 51k + 33k
    Rin = 1683k / 84k
    Rin = 20.04k
    ro = VM / ID
    ro = 50V / 0.634mA
    ro = 78.9k
    Vout = −gmVgs(ro || RD) ----------------------> It is VGS same with Vgs?
    Vout = -6mS Vgs ( 78.9k x 3.3k / 78.9 + 3.3k )
    Vout = -6mS Vgs ( 3.17k )
    Vout = -19.02 Vgs
    [​IMG]
  2. studentLab
    studentLab
    11
    Apr 21, 2014
    Vgs = ( Rin / Rin + 0 ) x Vin
    Vgs = ( 20.04k / 20.04k + 0 ) x 45mV
    Vgs = 45mV
    Vin = Vgs
    Vin = 45mV
    Vout = -6mS x 45mV ( 78.9k x 3.3k / 78.9 + 3.3k )
    Vout = -6mS x 45mV ( 3.17k )
    Vout = -0.856V
    Ac output gain = Av = Vout / Vin
    Av = -0.856V / 45mV
    Av = -19.02
    Do i doing right here?
  3. Ratch
    Ratch
    1,094
    334
    Mar 10, 2013
    For calculating K you are using a formula for the triode region of the MOSFET. Besides, you left out the Vds term. I think you want to use the formula for the saturated region which is Id = K*(Vgs-Vt)^2 , which gives K=0.006272 .
    Ratch
