Paolo, IK1ZYW, informs me my programs will run in a LINUX, DOSEMU
environment. I was not aware of this.
He has tried it with Dosemu 1.2.2.0
Thanks very much Paolo.
I use dosemu and have yet to run into a program that doesn't work with it.
The old DOS orcad works a lot better under dosemu than under XP.
Programs that use serial ports can even have the serial port changed with
no problem. The program thinks it is using COM1 with the normal address
and interrupt but is in fact using the second serial port.
The only problem I had getting it working was that they don't tell you
enough about the directory for lock files in the documentation. I had to
try it and see what happens.
