My picture tube is filled up. . . .
Discussion in 'Electronic Design' started by [email protected], Apr 16, 2013.
  1. Guest
    Posted - April 1, 2013
    I have a problem with my television. It appears that my picture tube is
    filled up with pictures. There is a message scrolling across the screen
    that says "Your Picture Tube is Full - To continue using this
    Television, please drain the old Pictures from the Tube". I'm sure I
    can do this, but I cant find the drain plug? Where is it? The tv is a
    1950 Motorola console model with 19.5 inch screen.
    After 63 years of constant use, I suppose it has reached it's limit. In
    fact the tv set weighs about 3 times as much as it did when I purchased
    it new, in 1950. It must be all those old pictures that add to the
    weight.
  2. hamilton
    hamilton Guest
    1. Open back of set
    2. Power up set till screen is at full brightness
    3. grab-a-hold of the BLACK rubber plug on the side of the picture tube,
    the one with the RED pull-cord attached.
    Keep pulling until all the pictures are drained out.
    Oh yea, keep smiling !!
  3. Sylvia Else
    Sylvia Else Guest
    It should be noted that pulling that plug can let quite a lot of
    pictures out even if the set has been turned off for days. People can be
    quite surprised.
    Sylvia.
  4. Phil Allison
    Phil Allison Guest
    ** Back in the 1950s, this yarn was quite a bit simpler.
    TV service guys would tell customers ( tongue in cheek ) that after a while,
    you will need to get them out to clear your set out of all the dead cowboys
    and Indians......
    ..... Phil
  5. Artemus
    Artemus Guest
    Safety first! All those pictures will be under a lot of pressure so
    be sure to wear safety glasses.
    Art
