D
[email protected]
PG&E came out and put in my "ENET" Time of Use meter, so I could officially
turn on my solar pv system and connect it to the grid.
I have 36 Kyocera KC125G panels on a Fronius IG4000 grid-tie inverter.
The inverter seems to come to life about the time of an official sunrise,
do some tests and synchronization for 5 minutes, and then come on line,
producing about 40 AC watts. It was sunny the afternoon the meter was
swapped out. I was producing 3800 AC watts while the PG&E guy was here.
Over the weekend, I hit a peak of 4170 AC watts. It turns off a little
after official sunset, and I've seen 31 watts in the evening.
Since then, it's been rainy and cloudy most of the time.
The new meter was started at a reading of 50000 kwh for peak and for
overall. It shows a display of how many kw are currently being pulled or
pushed, with a little arrow. (Go left. Go left.)
For a while, I was watching the peak reading go negative a little, to a low
of 49995 after two days, and the overall go up each day, to a corresponding
reading of 50046, then the rain came.
Now, I am seeing the peak going up about 3kwh per day, and the overall go
up about 30 each day.
The Fronius shows that it has produced 92kwh in 89:26 run time (some of
that before the meter was switched). 38kwh Jan28-Feb02.
I have the Fronius Home Monitoring software, but that's not working for me.
I can see the inverter display, but I'm not getting any history.
