T
The Great Attractor
. It's an interesting idea though I don't confess to
understanding how you envisage it working.
Which proves that you are just as fucking lost as he is.
I am currently daydreaming about electricity that is direct current
[and has no frequency], extremely high-voltage, thin-channeled, and
extremely low-amperage and a PC that runs on such electricity.This electricity is a max of only 1 watt. The amperage is a max of 1
electron per second. The width of the electric channel is only 1
electron thick, hence it is "thin-channeled". The voltage is high
enough that it can pass through air.In addition, this electricity does not generate any perceptible heat
when passing through air. A computer running on this electricity never
gets hot enough to need any cooling equipment. I can touch the
electric parts of a device when on, without feeling any heat.Since this electricity can pass through air without metal, it is
wireless.Chips using this electricity can tolerate electrostatic discharge
without being damaged to any extent.The PC running on this electricity is as fast as the world's current
best PC.In addition, this PC does not contain or need any storage devices,
vacuum-tubes, glassfets, GaAsFETs, fans, cooling devices, capacitors,
resistors, magnetic parts, moving parts, semiconductors, discs, or
ROM.All info in the PC is generated in real-time by the high-voltage, low-
amperage, thin-channeled current itself. So no storage devices are
necessary.This PC does not need much metal since the electricity flows through
air in the PC.
Radium
It's a great pity that people can't read an unusual post without
immediately kicking and clawing at each other to be the first to type
'fuckwad' and 'moron'. There are too many cowards in the world today.
(I can imagine them sitting in their lounge rooms watching Star Trek
and screaming "Mass approaches infinity at the speed of light!
Fuckwads!!")
He is an idiot with a proven track record of stupid ideas. Typically
of the form [regular idea] + [make a quantity 30 orders of magnitude
bigger or smaller] + [complete inability to understand explanations
why his idea is impractical and/or stupid].
If that is the case, then he should place it in his sig so everyoneHe is an idiot with a proven track record of stupid ideas. Typically
He has mentioned that he is autistic. There is an autistic person who
posts on another group I know of. He has a complete inability to
understand why his posts annoy people. Although rare, they can be
confusingly like trolls. You may encounter this guy soon...
why his idea is impractical and/or stupid].He has mentioned that he is autistic. There is an autistic person who
knows not to smack him around.
Radium said:All info in the PC is generated in real-time by the high-voltage, low-
necessary.
air in the PC.
In sci.physics.electromag Radium said:On May 12, 10:53 pm, The Great Attractor
Not necessarily. There are low-power PCs that are pretty fast.
In sci.physics.electromag Radium said:On May 12, 10:55 pm, [email protected] wrote:Radium wrote:
Hi:
What will you use as insulation, cerebro-fuckwad?
None necessary.
Clueless idiot.
What will you use as insulation inside the CPU, cerebro-fuckwad?
None necessary.
Clueless idiot.
Energy and power are two different things.Bremsstrahlung, cerebro-fuckwad.
Not at the small energy levels I'm talking about.
Clueless idiot.
I already said the power is only 1 watt, not nearly enough for
Bremsstrahlung.
In sci.physics.electromag Tim Polmear said:On 12 May 2007 12:02:17 -0700, Radium <[email protected]> wrote:
I don't know if your computer is practical, nor does it really matter.
Practicality never stopped Asimov filling all his robots with a
positronic brain which even the technicians of US Robotics couldn't
understand. It's an interesting idea though I don't confess to
I suggest you would spend your time better by building a computer that
runs entirely on photons from light. Be sure it can handle a wide range
of photon energy levels (wavelengths). If you can fabricate picogates
that can operate entirely by holding a single photon in state and switch
the next photon based on a held photon, then you may well have achieved
the elusive 100% energy efficiency. Holding a photon would be the big
trick (they prefer to move very fast, so you will have to fool it and
run it around in a circle or bounce it back and forth).
Hi:
wireless.
best PC.
ROM.
necessary.
air in the PC.
Regards,
Radium
Even a 4 bit light computer has the potential to be far faster than
anything we currently use.
My dream PC is at least 32-bit.
