R
Radium
Hi:
I am currently daydreaming about electricity that is direct current
[and has no frequency], extremely high-voltage, thin-channeled, and
extremely low-amperage and a PC that runs on such electricity.
This electricity is a max of only 1 watt. The amperage is a max of 1
electron per second. The width of the electric channel is only 1
electron thick, hence it is "thin-channeled". The voltage is high
enough that it can pass through air.
In addition, this electricity does not generate any perceptible heat
when passing through air. A computer running on this electricity never
gets hot enough to need any cooling equipment. I can touch the
electric parts of a device when on, without feeling any heat.
Since this electricity can pass through air without metal, it is
wireless.
Chips using this electricity can tolerate electrostatic discharge
without being damaged to any extent.
The PC running on this electricity is as fast as the world's current
best PC.
In addition, this PC does not contain or need any storage devices,
vacuum-tubes, glassfets, GaAsFETs, fans, cooling devices, capacitors,
resistors, magnetic parts, moving parts, semiconductors, discs, or
ROM.
All info in the PC is generated in real-time by the high-voltage, low-
amperage, thin-channeled current itself. So no storage devices are
necessary.
This PC does not need much metal since the electricity flows through
air in the PC.
Regards,
Radium
wireless.
best PC.
ROM.
necessary.
air in the PC.
Regards,
Radium
