music amplifier
Discussion in 'Electronic Basics' started by steve, Oct 30, 2008.
  1. steve
    steve Guest
    I need to amplify the sound from a 9 volt dc audible probe circuit.
    The probe provides a very low musical melody sound that cannot be
    heard.
    However, another audible probe circuit that only beeps, is audible.
    At the musical probe output, the voltage is very low, around micro
    volts.
    The audible probe outputs slightly higher voltage.
    Steve
  2. Guest
    Try this one.
    http://www.tricountyi.net/~randerse/amp.htm
    Michael
  3. ehsjr
    ehsjr Guest
    Simplest might be an LM386 amplifier IC.
    http://cache.national.com/ds/LM/LM386.pdf
    2 or 3 caps and a pot are the only other
    parts you need, besides a speaker.
    Ed
  4. ian field
    ian field Guest
    Simpler still is the TDA7052, its a BTL amp in the same DIL-8 package - the
    one with the "A" suffix has DC volume control.
  5. steve
    steve Guest
    Thanks to everyone for their views.
    Been bsuy lately .. will try and inform soon.
    Steve.
  6. neon
    neon
    1,325
    Oct 21, 2006
    forget lm386 that is for a vey poor power amp. use instead an lm555 oscillator it has plenty of power output and use pin 2 to fm the oscillator it only require 50 ua .
