Mura (cloudiness) on larger LCD tv's
D
Dan
I recently bought a Samsung LN-S4695D 46" LCD television. In general I like
the TV, except that dark scenes display vertical bars of lighter area
extending approximately 6 inches in from each side (i.e., 6" wide bars on
each end the height of the display) . This is especially apparent in
16x9/full screen images. I have seen quite a bit of comment on Sonys this
size regarding this defect. I guess I expected better from a $2500
television. I'm wondering if some of the experts here would comment on this
effect and any possible remedies. Is a set that has this problem simply
defective/irreparable? I am still within the 30 day return period (Circuit
City) but this is not an easy item to return, given its size. Any input
appreciated.
Dan
R
Roy Starrin
each end the height of the display) . Any input
appreciated.
You might muck around in here or some adjacent forum and see if your
model is discussed:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=166
D
Dan
model is discussed:
Thansk Roy, yeah I've been on that one. There is discussion of the problem
on the set. Apparently it uses the same screen as the 46" Sonys, which also
have a lot of comment re: this issue.
I'd like to know what the technical basis of this is. I gather it relates
to the way the screen is backlit.
Dan
R
Roy Starrin
Have you been to the dedicated thread?
http://www.avsforum.com/avs-vb/showthread.php?p=8866702&&#post8866702
There is also this, which has was in the Sony Kv2500 Calibration
thread
http://www.avsforum.com/avs-vb/showthread.php?p=8978826&&#post8978826
Beyond that, I'm at a loss. Am not a techie. Just came across this
while doing research as to what my next (first) LCD will be.
appreciated.
Dan
Dan,
Did you return your Samsung? I just purchased the same model on
Amazon.com and am noticing the exact same problem. Is this a defect?
Eric
John
Dan,
Eric
Most likely just a design pushing the limits of the technology. LCD
screens work OK up to 26-27" (with a few OK at 32"), but the consensus
of Consumer Reports and the like is that for a screen larger than 32",
you bite the bullet and go with plasma.
We're 90% happy with our 26" Sharp: the view angle isn't a wide as I
would like and large black areas are more dark gray than black - both
typical of LCDs.
John
R
Roy Starrin
'Twas that way once, but no longer. Read the March 2007 Consumer
Reports. My family room is too bright to bite the plasma bullet
