Multiplying Voltage by a factor
Discussion in 'General Electronics Discussion' started by Prakash Gautam, Jun 9, 2014.
  1. Prakash Gautam
    Prakash Gautam
    6
    May 16, 2014
    I am trying to make a data aquisition system that converts analog voltage to digital value by use of ADC. Since the voltage input range of ADC is limited (5V in the device I am using), but my aquisition system needs to record voltages more than this. So I would want to attenuate higher voltage and magnify the smaller voltages. So how I am thinking of op amp for the purpose. So how can I make one?
    Any references are welcome.
    Thank you in advance.
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    Trans diode Logarithmic amplifier might work. This scales down large input signals and allows you to measure them while still allowing small signal to be measured. But the output is the log of the input so you will need to convert it back in software if you need to.
    Adam
  3. KrisBlueNZ
    8,393
    1,267
    Nov 28, 2011
    Sounds like you want some kind of auto-ranging system like multimeters have. This requires a variable attenuator that selects between several attenuation factors (often with 10:1 ratios) under software control.
    You need to tell us a lot more about your application and requirements.
  4. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    You can also use an ADC with a variable or selectable voltage reference, again under software control.
  5. Prakash Gautam
    Prakash Gautam
    6
    May 16, 2014
    My input voltage range is 0-20V and I want to pass this voltage through some circuit so that I get the output 0-5v ( $V_0=.25*V_i$)
  6. (*steve*)
    25,293
    2,732
    Is there any reason you can't use a resistive voltage divider?
    Are you just passing the voltage, or does the circuit you're passing it to expect to sink some current from it (if so, how much)?
