Multiple voltage supply
Discussion in 'CAD' started by captoro, Sep 8, 2008.
  1. captoro
    captoro Guest
    Hello I am using the PSPice Orcad
    I have many drivers with the same voltage. Is there a way to do the
    simulation with only that voltage and use reference point to that
    voltage instead of using multiple line from the source to each driver.
    This would reduce a lot the amount of lines and would make things much
    clearer.
    THANKS,
    k
  2. qrk
    qrk Guest
    You can use net names. All wires with the same net name will be
    connected in the net list.
  3. Charlie E.
    Charlie E. Guest
    there are also teh power and ground symbols that name the net
    automatically, but lets you represent the power supplies they are
    attached to. Find under Place/Power and Place/Ground
