Multiple Inputs/Outputs transmitter
Discussion in 'General Electronics Discussion' started by Anon_LG, Jul 25, 2014.
  1. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    I am about to receive my first RF receiver and transmitter broadcasting in the 433-434 Mhz band. I am going to be using a multiplexer to transmit several bits of information. If there is anything that I should know please could I be told, this is my first try with RF transmitters and receivers.
  2. BobK
    7,674
    1,684
    Not sure what you mean by that. These transmitters are usually set up to transmit serial binary data, not analog, if that is what you mean.
  3. KrisBlueNZ
    8,393
    1,267
    Nov 28, 2011
    Can you provide manufacturer and part numbers for the transmitter and receiver? Link to data sheets?
    Do you want to do this without microcontrollers?
  4. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    I require a IC which has several inputs, the IC then interprets these inputs and sends the interpreted form to a transmitter, the transmitter outputs this one output into another IC which the undoes the interpretation, giving the original inputs as outputs. These inputs/outputs would only be digital. I would prefer not to use microcontrollers. This is where the specs are for the transmitter and receiver.
    http://www.seeedstudio.com/depot/433Mhz-RF-link-kit-p-127.html
    I think what I actually need is an encoder and decoder?
  5. BobK
    7,674
    1,684
