You are 'clearly' retarded in making assessments, and have no place
doing so, asswipe. The rat's maze example was ALL about your 'path
difference' question. When you're all done bitching about all this stop
to remember that these are digital packets being sent back and forth. The
industry has been pretty good at making that happen, and one person
constantly pitching a bitch about all his problems being due to multipath
distortion pretty much gets shot to hell the moment the WLAN handshake
takes place between the two points.
No. You have a case where the claimed problem has been claimed to be
different than the standard case. That doesn't mean that it is, nor does
it mean that the observer is making the proper observations, nor does it
mean that he is qualified to make any such observations. Bitching about
multipath is common with this guy, and that should set an alarm flag for
everyone, but doesn't for some reason.
I don't need a primer, dumbfuck. I've worked with diversity receivers
in this band for five years at least, ending a few years ago.
True diversity has signal processing which detects any multipath and
uses that as a factor in determining the best antenna to use for a
signal. It also has the capacity to cancel or ignore the reflected
signal components. It doesn't just pick the highest power level signal.
It picks the BEST signal. WLAN routers do NOT perform their claim of
'diversity' between the two closely spaced antennas on their router case
the same way the true diversity industry does.
First off, I do not need your fucked in the head 'you gotta post like
this' stupidity. 2ndoff, you can **** off trying to tell folks what to
do with their posting in Usenet.
Look, asswipe, I was referring to multipath, idiot! I have posted into
this thread several times and ALL have been on topic and to the thread,
you idiotic piece of shit.
I was also referring to the solution the dope needs, you dopey,
no-you-are-NOT-a-moderator IDIOT! Not that I need to subscribe to your
retarded assessments for reply criteria to begin with. In other words,
you retarded asswipe, **** YOU. **** off and die! You stupid ****.
