multimeter not working
Discussion in 'Troubleshooting and Repair' started by ventsyv, Dec 30, 2014.
  1. ventsyv
    ventsyv
    29
    Dec 3, 2014
    I have GE 2524 digital multimeter i haven't used in a few years that won't turn on. I changed the battery and the fuse looks ok.
    The positive terminal on the old battery looked corodded but the battery was not leaking.
    I was wondering if the type of battery i put in matters? The old one was GiCell 6f22 9v super heavy duty, the new one is energizer 9v 522 6LR61-6am6.
  2. ventsyv
    ventsyv
    29
    Dec 3, 2014
    Nevermind, Wikipedia answered my question, 6f22 is zinc-carbon and 6LR61 is alkaline, other than that they are the same thing as far as i can tell.
  3. davenn
    davenn Moderator
    13,734
    1,915
    Hi
    welcome to EP :)
    so I assume its still not working ?
  4. ventsyv
    ventsyv
    29
    Dec 3, 2014
    Correct, it's still not working. I'm at a loss, there is not much to it that can break.
  5. davenn
    davenn Moderator
    13,734
    1,915
    OK ... did you accidentally measure a high current or voltage in the incorrect range ?
    open it up and take some sharp and well lit pics of the circuit board and post them here and
    lets see if anything is obviously damaged
  6. ventsyv
    ventsyv
    29
    Dec 3, 2014
    Picture 5 has a smudge that upon closer inspection appears to be some sort of epoxy like substance.
    This is the back side of the bottom left corner of picture #2
    https://www.dropbox.com/sc/gi8lcg2it2xgrgv/AAAvPXWReaJNcdLdXB7T-kvZa
    Other than that nothing stands out.
    I've not used it in years and before that I only used it a few times, I doubt I measured anything high current, though I can't rule it out, I'm pretty much a newbie when it comes to electronics.
  7. davenn
    davenn Moderator
    13,734
    1,915
    Hi
    if you are referring to the smudge on the upper left of pic4 and lower left of pic 5
    that's just some solder flux
    I don't see any other obvious problems ... cooked components
    do you have another multimeter ? ... you need to measure some things....
    firstly the voltage of the new battery --- it may be flat
    with the battery plugged in you need to measure the voltage at the red and black wires at the circuit board end and make sure there is 9V there
    You need to Ohms test the fuse and make sure it has continuity
    there's first few tests you really must do :)
  8. ventsyv
    ventsyv
    29
    Dec 3, 2014
    I wish I had another one... I shorted the battery (put a screwdriver across the terminals) and there was a small spark. It's a brand new battery I ordered it maybe 6 months ago. The other ones went in my smoke detectors, this is the last one. I guess I'll ask my friends if anyone has a meter, and I'll by some extra 9Vs, never hurts to have spares.
  9. ventsyv
    ventsyv
    29
    Dec 3, 2014
    OK, I'm getting 9V from the battery and the fuse appears to be OK - measured 0.8 ohms, which I assume is the correct resistance. I got another multimeter but I would like to find out what's wrong with this one. (I'm trying to learn electronics).
    Any suggestions where to look next? Maybe the display is not working?
  10. KJ6EAD
    KJ6EAD
    1,114
    158
    Aug 13, 2011
    You need to make sure the 9V is getting to the board. Don't underestimate the deleterious effects of corroded battery contacts.
  11. shrtrnd
    shrtrnd
    3,785
    501
    Jan 15, 2010
    You said there was some corrosion on one of the battery contacts even though the battery wasn't leaking. I'm wondering if the meter was stored in an atmosphere that that allowed oxidation of contacts
    inside the meter. If the display is an LCD, my first guess would be the contacts to the LCD itself (need cleaning). Is this an LCD o LED display?
