Multifamily solar heating
Discussion in 'Home Power and Microgeneration' started by [email protected], Sep 5, 2004.
  1. Guest
    ....As drawn, it looks like we have 50x86 = 4300 ft^2 of heated ceiling and
    2(50+86)17 = 4624 ft^2 of walls enclosing the living space, of which about
    120 ft^2 is 1st-floor south windows (excluding the stairwell windows) and
    148 ft^2 is 2nd-floor south windows and 193 ft^2 is north windows, with
    71 ft^2 on the east and west walls. That's about 603 ft^2 of windows, ie
    7% of the floorspace.
    With 0.1 air changes per hour (very tight, about 40 ACH in a 50 Pa blower
    door test), it would naturally leak about 0.1x4300x17/60 = 122 cfm, enough
    for 8 full-time occupants at 15 cfm each. An efficient air-air heat exchanger
    (eg a bidirectional fan in a partition wall) in series with a humidistat
    might provide the rest of the fresh air.
    R14 walls and an R34 ceiling (eg 6" of fiberglass under 2" foamboard) and
    R2 south windows with 80% solar transmission with R4 and 50% for the rest
    would make the thermal conductance to outdoors 268ft^2/R2 = 134 Btu/h-F for
    the south windows + 335/4 = 84 for the rest of the windows + (4624-603)/14
    = 287 for walls + 4300/34 = 126 for the ceiling + 122 for air leakage,
    totaling 753 Btu/h-F.
    NREL data indicate January is the worst-case month for solar house heating
    in NYC, when 610 Btu/ft^2 falls on a square foot of ground and 980 Btu falls
    on a south wall on an average 31.5 F day with an average daily high of 37.6,
    for an average daytime temp of 34.6 F. East, west, and north walls get 410,
    410, and 190 Btu. On a clear vs average day, 690 Btu falls on the ground
    and 1800 falls on a south wall. The average temp is 76.8 in July, with 1910
    Btu on the ground and 850 on a south wall. The yearly average (water) temp
    is 54.7, with 1260 and 1510 Btu on the ground and on a south wall.
    On an average January day, the south windows would collect 0.8x980x268
    = 210.1K Btu, IF unshaded. The upper south windows might collect more with
    a light colored porch roof. The rest would collect 0.5(410(71+71)+190x193)
    = 47.4K Btu, for a total solar gain of 257.5K Btu/day.
    An average US family uses about 10,000 kWh per year of electrical energy,
    ie about 2500 kWh per year per person. (Steve Baer and his wife use a total
    of 960 kWh/year :) If 55 energy-frugal people use 1/4 of the US per capita
    average amount of electricity indoors, ie 55x2500/4 = 34.4K kWh per year,
    that adds 34.4Kx3410/365 = 321K Btu/day... 55 people sleeping 8 hours would
    add 253x55x8 = 111K Btu/day.
    The house needs about 24h(65-31.5)753 = 605K Btu of heat on an average
    January day. Solar gain and electrical use and people might provide
    (257.5+321+111)/605, ie 114% of that. On a cloudy day, electrical use
    and people might provide (321+111)/605, ie 71% of the heat. R32 walls
    and an R60 ceiling would make it 100%. So would 12" R48 SIPs.
    The hydronic slabs can help spread solar heat around and store it overnight.
    Three solid 6" x 4300 ft^2 slabs have about 3x4300x6/12x25 = 161K Btu/F of
    heat capacitance. RC = 161K/842 = 192 hours, which could be raised with a
    big water tank. Tim Ellison spoke on his "House with a 10-day time constant"
    at the last Portland, ME ASES conference. A radiant floor and "3 3000 gallon
    plastic septic tanks in an outdoor strawbale sculpture." Unfortunately,
    the tanks contained room temp vs hot water.
    With no gain, a 192-hour house would cool from 70 to 30+(70-30)e^(-18/192)
    = 66 F over an 18 hour 30 F night. A good passive solar house with a longer
    time constant (eg a "Barra house" with a hydronic floors over spancrete with
    4"x6" holes on 8" centers and a large heat storage tank and thermosyphoning
    air heater panels on the south wall) might store heat for 5 cloudy days,
    gradually cooling to 60 F, but it wouldn't provide domestic hot water.
    A 10 minute 1.25 gpm 110 F shower needs 10x1.25x8.33(110-55) = 5727 Btu...
    55 showers per day would be 315K Btu. An 80% greywater heat exchanger might
    preheat fresh water to 55+0.8(105-55) = 95 F with 105 F drainwater from
    fully-enclosed showers, reducing the water heating to 55x10x1.25x8.33(110-95)
    = 86K Btu/day, but that might require lots of money and floorspace. Graywater
    might flow through 1,000' of 4" PVC pipe in the floorslab, but how would we
    keep the pipe full without serous clogging? Some septic systems use filters
    with nylon stockings surrounding 4" pipe...
    Including DHW, we need 5(605K-432K+315K) = 2440K Btu for 5 cloudy days in
    a row. With perfect temperature stratification, this might come from two
    1500 gallon 5' deep x 8' diameter insulated tanks with copper coil heat
    exchangers. Over 5 cloudy days, one tank would cool from 170 to 54 F, the
    other from 170 to 80 F. STSS () makes standard UL-approved
    flexible circular metal tanks and heat exchangers like this for $1-2 per
    gallon. They are widely used with Tarn woodstoves (although wood is ongoing
    work, compared to solar heat.) DHW would flow through a heat exchange coil
    in each tank. On cloudy days, the warmer tank would heat the slabs.
    A solar attic like those in Soldier's Grove with water vs warm air heat
    collection could heat the tanks with 2 low-power circulating pumps and
    heat exchange coils with water from a 6' wide x 72' long greenhouse
    polyethylene film heater atop a 6'x60' east-west strip of horizontal PV
    panels on the attic floor, with a 6'x12' higher temp heater section with
    the poly film pillow covered with 2 additional layers of polycarbonate
    glazing, with no PVs beneath it. This polycarbonate glazing costs about
    $1.50/ft^2 in 4'x50'x0.02" rolls, with a 10-year guarantee against loss of
    light transmission, outdoors. The 72' heater might be south of an 80'x12'
    high reflective wall under the attic ridge, with an EPDM liner beneath
    for leak protection. The 12/12 south roof could be a 17'x80' single layer
    of corrugated polycarbonate Dynaglas greenhouse roofing in 20 overlapping
    4'x17' sheets.
    Greenhouse film comes in wide rolls, costs 5 cents/ft^2, and has a 4-year
    guarantee outdoors, exposed to wind and UV. Water-filled poly film ducts
    on the ground store overnight heat in Israeli greenhouses. I've boiled this
    6 mil UV-inhibited polyethylene film with no apparent change in properties.
    Its refractive index is close to water and glass, and water absorbs longer
    wavelengths than PVs use, and thin layers of water and poly film don't
    absorb much, so the heater won't greatly reduce the PV output. When I put
    two layers of poly film with an inch of water between them over a PV panel,
    the electrical output (Isc) only dropped 6%.
    A 6'x60' PV array would normally make about 3.6 kW, peak, but the reflective
    wall could double that in summertime. This could also work with a smaller PV
    array, or none at all, to begin with. The water would drain down at night in
    wintertime. It might stay in the heaters all the time with gable attic vents
    open in summertime.
    The attic would collect about 0.9x12x80(1910+850) = 2385K Btu on an average
    July day (less, because of the reflective wall shading, and still less, with
    white cloth over the south 6' of the floor.) If 0.15x2x6x60x0.9x1910 = 186K
    of that becomes electricity and 315K Btu heats water, 2385K-186K-315K = 1884K
    Btu is left, ie 1884K/24h = 79K Btu/h. With lots of water inside the attic
    and 8 ft^2 gable and floor vents, 79K Btu/h = 16.6(16ft^2)sqrt(12)dT^1.5
    makes the attic-to-outdoor temp diff dT 19.4 F, with a 16.6(16)sqrt(12x19.4)
    = 4050 cfm airflow (which might serve as a whole-house fan at night.) The
    average attic temp would be about 76.8+19.4 = 96.2 F in July, or less, with
    a thin layer of evaporating water over the heater. Cooler PVs produce more
    electricity.
    Vents through the reflective wall and the north roof could lower the attic
    temp more. The north attic roof might extend above the south roof, with 2'
    of south-facing windows above it, open in summertime, and a linear lightshaft
    below that that leads to some simple skylights in the attic floor. With roof
    insulation and heat from the south attic, people might use the space below
    the north roof, about 80'x18', down to a 6' headroom.
    This is a sketch. A simple computer simulation would be useful, something
    that shows the house would not have required any backup fuel at all over
    the last 30 years, using NYC hourly weather data.
    Nick
    APPENDIX: Solar attic collection details
    With R33 insulation (R14 urethane plus a 6" fiberglass wrap), each tank
    would lose about 24h(170-65)150ft^2/R33 = 12.5K Btu/day in a 65 F space
    We want to collect at least 25K Btu/day at 180 F plus 315K Btu/day at
    120 F or more.
    The tanks and heaters might be plumbed like this (viewed in a fixed font,
    eg Courier):
    A 6'x12' wood polycarbonate frame polycarbonate
    could be laid over the end of | |
    the polyethylene film heater. polycarbonate
    polyethylene film.................polyethylene film
    ->| 1-2" of water |<--
    | polyethylene film.................polyethylene film |
    | PV---------------------------------PV | attic floor |
    | <--60'--> | <--12'--> |
    | initial/final temps | |
    | pump 170/54 | 170/110 | pump
    | ^ | | | 120 F | | | | ^ |
    | | * | ground floor | * | |
    ------- *** heat exchange coil -------
    120/54 170/110
    The DHW and radiant floor heat exchange coils are not shown above.
    On an average January day, a 12'x12'x80' long attic solar aperture with 90%
    transmission might collect 0.9x12x80(610+980) = 1374K Btu over 6 hours at a
    rate of 229K Btu/h. With an attic air temp T, 1358 ft^2 of R1 glazing would
    lose (T-35)1358 Btu/h. A 6'x60' EW strip near a 90% reflective wall might
    receive something like 58.2K Btu/h of net heat on an average January day,
    after subtracting the electrical output energy.
    If the PV heater glazing film conductance to room air is 1.5, the heaters
    might gain (T-120)6x60x1.5 = (T-420)540 Btu/h from warmer T (F) attic air.
    The polycarbonate heater might gain 10.9K Btu/h and lose (180-T)72ft^2/R2.
    So we have something like this, viewed in a fixed font:
    120 F T = attic air temp (F)
    |---|-->|---*---www---*---www--- 35 outdoor temp (F)
    --- | 1/540 | 1/1358
    PPN = | |
    58.2K Btu/h--- I1--> | (See the BASIC program below.)
    X Opening the circuit at X and replacing the part
    | above with its (Thevenin) equivalent gives the
    180 F | simplified circuit below...
    |---|-->|---*---www---* Rt = 1/(540+1358) = 1/1898,
    --- | 2/72 |
    10.9K Btu/h | | 1/540+1/1358 = 1/386,
    --- | I1 = (120-35)386 = 32841 Btu/h, and
    - | Vt1 = 35+I/1358 = 59.2 F.
    159.9K Btu/h
    180 F T
    |---|-->|---*---www-Y-*---www---
    --- | 2/72 | 1/1898 | Vt1 = 59.2 F
    10.9K Btu/h | | |
    --- | --- Opening the circuit at Y and
    --- | - replacing the parts to the right
    | | | and below with their equivalent...
    --- | Vt2 = 59.2+159.9K/1898 = 143.4 F.
    159.9K Btu/h
    180 F T = 143.4 + (180-143.4)/(1/36+1/1898)/1898 = 144.1 F.
    --- | 2/72 1/1898 | Vt2 = 143.4 F
    10.9K Btu/h | |
    So the 180 F collector gains 6h(10.9K+(144.1-180)72/2) = 57.6K Btu/day
    and the 120 F PVs gain 6h(58.2K+(144.1-120)540) = 427.2K Btu/day.
    10 PA=.9*12*80*(610+980)/6'solar power into attic (Btu/h)
    20 PC=.9*(6*610+.9*1.5*980)/4/6'solar power on collectors (Btu/h-ft^2)
    30 LPV=60'PV array length (feet)
    40 SPV=6*LPV'PV array surface (ft^2)
    50 SCC=6*72-SPV'180 F collector surface (ft^2)
    60 PPV=SPV*PC'total heat power into 120 F PV collector (Btu/h)
    70 EPV=.15'PV efficiency
    80 OPV=.9*PPV*EPV'electrical output (Btu/h)
    90 PPN=PPV-OPV'net heat power into 120 F PV collector (Btu/h)
    100 PCC=.9*.9*SCC*PC'solar power into 180 F collector (Btu/h)
    110 VT1=35+(120-35)/(1/(1.5*SPV)+1/1358)/1358'first Thevenin temp (F)
    120 RT=1/(1.5*SPV+1358)'Thevenin resistance
    130 VT2=VT1+(PA-PCC-PPV)/1790'second Thevenin temp (F)
    140 T=VT2+(180-VT2)/(2/SCC+RT)*RT'attic temp (F)
    150 Q120=6*(PPN+(T-120)*1.5*SPV)'heat collected from PVs (Btu/day)
    160 Q180=6*(PCC+(T-180)*SCC/2)'180 F collector heat (Btu/day)
    170 PRINT SPV,SCC,VT1,VT2
    180 PRINT T,Q120,Q180,Q120+Q180
    120 F PV 180 F Coll Vt1 (F) Vt2 (F)
    360 ft^2 72 ft^2 59.18335 143.4245
    Air temp (F) PV heat Coll heat total heat
    144.1053 427235.2 57633.67 484868.8 Btu/day
    With no venting, the air in my 768 ft^2 attic with a 12/12 south 600 ft^2
    single-layer polycarbonate roof and uninsulated stone walls (part of an
    1820 stone farmhouse) gets up to 143 F in December. It's a good place
    to dry laundry or flowers or escape winter blahs for a few minutes...
    <end of appendix>
  2. Guest
    Others would probably do this work. I'd stand behind the engineering.
    It's fairly straightforward, altho it may be simpler and more efficient
    to run 54 F well water through the PV heater, with no heat exchanger or
    circ pump, and repressurize the DHW on the way out of the tank. The tricky
    part would be making the hot and cold water pressure equal. When I tried
    this at home with two pumps and hot rainwater and cold wellwater, showers
    were very invigorating. The water temp varied from about 60 to 110 F in
    a 2 minute cycle :) A temperature regulating mixing valve or a bladder
    tank might fix that problem.
    Nick
  3. Don Ocean
    Don Ocean Guest
    Typical Nick bullshit.. A real Engineer is hands on. With Nicks
    type of Engineering our space program would be blowing grains of
    sand out of antholes! He is a hobbybaby. Just toyland crap!
  4. Don Ocean
    Don Ocean Guest
    Cash up front first!! You want professional .. You pay professional!
    We don't leech a freebee paycheck from some taxpayer system like you do!
  5. ~^Johnny^~
    ~^Johnny^~ Guest
    Hook it up to some spa jets and use it for contrast baths. ;->
  6. Steve Scott
    Steve Scott Guest
    What do you do when the roof needs replacing?
  7. You carefully remove the PV panels, replace the roof and carefully
    put the PV panels back. What did you expect? A roof that is covered
    in PV panels shouldn't need replacing as often. If you use PV panels
    built in to a roofing product then they become the roof and should
    last at least the 25 year warranty period.
    2000 ft^2 is about 185 m^2. If we figure an average insolation of
    some 5 kwh/m^2/day and an efficiency around 10% (after thermal
    losses) this works out to about 92.5 kwh/day and 2800 kwh/month.
    Obviously there would be more in the summer and less in the winter.
    Around these parts, a typical home of this size might use anywhere
    from 12kwh/day to 24kwh/day for everything except HVAC. Heating
    or Air Conditioning can typically run in the 24kwh/day range.
    A good electric car can get 3 miles/kwh and the typical commute
    around Los Angeles is about 40 miles/day so a two car family would
    need some 27 kwh/day. This adds up to 75 kwh/day or 81% of the total.
    They may have 19% to spare on an average day. With some conservation
    measures, extra insulation, etc. they might bring that down to some
    46 kwh/day max or 50%. Of course, in the winter there is less light
    so this would change the numbers.
    They could always go cover the garage with PV or place panels on
    trackers or racks in the yards (assuming they have yards).
    It wouldn't be cheap. Even with an installed cost of $5/watt that
    120 kw (STC rating) of PV is going to cost $600,000 without including
    inverters or batteries. This is almost the price of a 2000 sq ft home
    around here.
  8. It buys you THREE of them around here - and I mean Nice, New,
    and With some land' :)
    Paul ( pjm @ pobox . com ) - remove spaces to email me
    'Some days, it's just not worth chewing through the restraints.'
    HVAC/R program for Palm PDA's
    Free demo now available online http://pmilligan.net/palm/
    Free Temperature / Pressure charts for 38 Ref's http://pmilligan.net/pmtherm/
  9. wmbjk
    wmbjk Guest
    FOUR in NW Arizona. Hey Anthony, ever considered moving to a lower
    cost of living area? Thousands of newbies will moving onto off-grid
    properties nearby in the coming years, many of them with serious money
    to spend from the sale of their CA places, and most needing help with
    their setups. Could be a great business for someone with your
    patience. Some people do complain about the dearth of culture here,
    but that's no longer an issue since a Home Depot opened last week. :)
    Wayne
