Hey all!
I have a problem I hope you can help with, if at all possible.
Our research group has built a rig for an experiment next week which contains a number of components (stepper motors, light gates etc), all requiring different voltages. As it stands, it needs a 12V feed (with 1-2 amp draw, depending on how many motors are running), and a 5V, 3V and 1.2V with minimal current draw. I'd ideally like to power everything off one power supply adaptor, although I realise due to the massive differences in current draw, it might be simpler to have the 12V drivers on an isolated power supply, this is no problem.
Is there a straightforward means of creating seperate 5V, 3V and 1.2V feeds from the one 5V adaptor?
I looked into simple resistor based voltage dividers, but I fear that the components would interfere with one another as they are switched on and off.
If you could point me in the right direction, that'd be fantastic. Thanks in advance!
