D
daestrom
Neon said:So in addition to a reactor operator and sub captain and an engineer,
now you're a motor man. Fascinating.
Nope. It's really simple, started out as an electrican on submarines in
nuclear power. Worked my way up to chief petty officer and along the way
did a tour in R-3 which is Navy lingo for Repair-3 on a sub base. Can you
guess what kind of repair facility R-3 is that they would have need for some
Electrican's Mates? After I got out, I went to work in commercial nuclear
power in operations and went to school to get a degree. Not at all that
fascinating. Pity you aren't in operations yourself instead of just
deconning a shutdown plant or you probably would have recognized the career
path, it's not unique.
Well, let's see how that holds
up to scrutiny. I don't know WHO you are but I know WHAT you are - a
lying bull-sh*tter. And a crawfish, of course. To address just one
of your claims, that a fan motor's thermal protection has to be in a
slot (or some variation thereof, I really couldn't keep track),
tonight I did a little work.
See, I really DO moonlight in a motor shop, Jerry's Electric Motor
Service in Cleveland, TN, as a matter of fact. I decided to pull a
fan off the shelf and dissect it. in the process taking "8X10 Color
Glossy Photographs" that would have made Arlo Guthrie proud. This
text-only format doesn't lend itself very well to graphical
presentation so without further ado, shall we shift to my blog?
Hmm... you took apart one fan motor and now you know more about EE than
anyone else on the planet. And from your example, you claim that all motors
are built the same way. Nice try. I've probably cleaned out and rewound
more motors than you've even had a chance to wire up the leads to.
http://www.johndearmond.com/2008/10/01/dissection-of-a-furnace-fan-motor/
For Part 2 of this little "Daestrom Disrobing", I'm going to
reassemble that fan after instrumenting it with thermocouples, run it
at various speeds and present the test results, again to demonstrate
just how full of excrement you and your sycophants from
alt.engineering(sic).electrical are.
Ah, when confronted with recognized experts, you crabwalk sideways and try
to discredit the experts. Don for one has more experience in electrical
machinery than you could ever hope for. At least this time you didn't run
away like the schoolyard bully when an adult shows up by removing the
newsgroup that disagrees with you. There may be hope for you yet.
Since none of you had the spine nor the balls to put your money where
your mouths were, I'm going to do it just for fun.
Ah, again with the name-calling and narrow-mindedness. If someone doesn't
accept your wager you assume the worst about them. It probably never occurs
to you that I don't take wagers for another reason. So childish of you.
I'll put a
thermocouple under that cute l'il thermal switch. I think I can
slide a fine one a little ways into a slot - just to demonstrate the
BS about slot temperatures in small motors. And I'll have a
recording spot infrared pyrometer looking at the rotor just for added
fun. Of course, it'll be instrumented for electrical parameters.
In fact, I think that I'll run several different brands of motors
just to demonstrate that there is so little difference between 'em as
not to matter. Finally, if I have time and still have the notion, I
think that I'll run a motor that WON'T operate on a phase angle
controller to show folks what that looks and sounds like.
Then it all goes up on my blog, complete with links from Google
Groups to this and the original thread. This'll take a couple of
days so don't go away.
The only question left to resolve is what you'll claim to be next.
Or what nym you'll use now that daestrom has become so toxic and
discredited.
Nice try. Again with the schoolyard antics. If you bothered to look (but
then you might learn something, heaven forbid), you'd find I've been posting
with this 'nym' for quite a few years now. Unlike some, I don't use a
different 'nym every week or two. Other than the few crackpots that think
energy is free, you're about the only one that has had a long running feud
with me. You're the relative newcomer to this group, unless you were
lurking for the past four or five years yourself under a 'nym'.
Now, if you really knew very much about motors, you'd know that induction
motor speed is a function of line frequency, number of poles and the amount
of slip the rotor undergoes. And you'd know that the pull out torque point
for most motors (even furnace blower motors) is above 75% of synchronous
speed. That means voltage reduction at best can reduce the speed down to
about 80% and can't get anywhere near the OP's desired 50% without shifting
below the pull-out torque point. Operating on the 'backside' of the
speed-torque curve is a really bad place to be.
Even the folks making portable box fans you can buy at the department store
have recognized that the best way to get 50% speed out of an induction motor
is to use a different combination of windings to get a different number of
magnetic poles. For them cost is king and if switching a capacitor in
series with such a fan motor were all that was needed (as you suggested in a
post), that would certainly be cheaper than bringing four or five leads out
from the motor to the switch. Guess those manufacturers would rather not
burn out their motors. Or can you site a commercially available induction
motor that shifts speed by adding a capacitor in series? I won't hold my
breath on that one.
By the way, remember this statement of yours?
"A centrifugal blower is a square law device. That is the flow is
proportional
to the square of the speed. 1140 RPM will probably drop the flow by half."
Go back and look it up. The flow is linear with speed, it is the head that
follows the square of speed. Google for 'pump affinity laws' or 'fan curves
explained' or some such if you don't believe me (which, of course you
won't). The basic affinity laws apply for any centrifugal device where the
density of the fluid doesn't appreciably change while going through the
device. And power follows the cube of speed.
Bet you snip that little mistake out of your reply. Or you just pass it off
as a minor typo. But I'm sure the one thing you *won't* do is admit you
were wrong.
Repeating again so you just might get the point, lowering voltage on a
squirrel cage induction motor doesn't drop the speed linearly with voltage
applied. Not unless it is a very small one with a high resistance winding
or specially designed with a very lower L/R ratio. And low L/R ratio motors
are rare, I doubt you could even find one.
If you don't believe that, go study wound-rotor motors. These are often
used in variable speed applications (and other special applications where
very high inertia loads require special starting considerations). The
principle of wound-rotor motors use the phenomenon of shifting the maximum
torque point towards a lower speed point by increasing the R of the rotor
circuit. But I doubt you'll find a single-phase motor of the wound-rotor
design. I only mention it because it is a concrete example of how to lower
the speed of an induction motor without shifting the winding connections.
daestrom
P.S. Did you know that the maximum torque point is defined by the rotor
resistance being equal to the reactance? No, of course you didn't, that's
just some detail that gets in the way of your view of the world. But I had
to learn details like that over 30 years ago just to make rate in the Navy
as an Electrican's Mate.
