Multi location thermostat
Discussion in 'General Electronics Discussion' started by dastk, Dec 2, 2015.
  1. dastk
    dastk
    May 27, 2009
    I have an apartment upstairs which is heated by the same system as our home downstairs. I would like to find a thermostat thet would take at least two inputs that would be switchable or even sharing.
    Anybody got an idea?
    Don
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    A thermostat measures the temperature at one location only. You could use two thermostats and some logic to give the action you want.
  3. CDRIVE
    4,960
    652
    May 8, 2012
    Multiple thermostats on a system that's not independently controlling the temperature of each location makes little sense.
    Chris
  4. Tha fios agaibh
    Tha fios agaibh
    2,215
    738
    Aug 11, 2014
    If regulating temperature is your goal, converting your furnace to two stage might be the best option.
    A damper will then switch from heating the upstairs, and then the downstairs.
    Martaine2005 likes this.
  5. Martaine2005
    Martaine2005
    3,653
    994
    May 12, 2015
    I don't know much about logic between two thermostats.
    As already pointed out, a thermostat will only turn on or off at the set temperature selected.
    Normally the highest area is the hottest area. So if it's colder downstairs, put the thermostat downstairs.
    But us Brits have loads of thermostats throughout the house!
    One for main hall/house temp, and the rest are all on radiator valves.
    Every room can be individually temperature controlled..
    But there are also these neat things that are wireless thermostats. You can have it in your back pocket and the temperature changes depending on your location within the property..
    Even iphone apps too...Automation is now! Not the future.
  6. CDRIVE
    4,960
    652
    May 8, 2012
    Where I live if it gets too cold in the house we just turn off the AC. If that doesn't work we open a window. :)
    Chris
  7. Martaine2005
    Martaine2005
    3,653
    994
    May 12, 2015
    British heatwave..
    duke37 and CDRIVE like this.
  8. Tha fios agaibh
    Tha fios agaibh
    2,215
    738
    Aug 11, 2014
    That doesn't solve the problem. That would only make the upstairs roasting hot. I assume it's forced air heat rather than hydronic heat. Closing the registers downstairs and opening the upstairs will compensate for a hot upstairs.
    You Brits have lots of thermostats, but, the down side to hydronic heat (boiler circulating water) is controlling the humidity. The gets dry.
    Got dry cracked skin Martin?
  9. Tha fios agaibh
    Tha fios agaibh
    2,215
    738
    Aug 11, 2014
    I would move in with Uncle Chris if I was you.
    CDRIVE and Martaine2005 like this.
  10. Martaine2005
    Martaine2005
    3,653
    994
    May 12, 2015
    John, that's a little below the belt!
    Who said I have sk.......never mind!
    Exactly....I stay downstairs..
    Uncle Chriiiiiiis....Got a spare humid free room, not too cold! But warm upstairs? And do you have cookies?:)
  11. Tha fios agaibh
    Tha fios agaibh
    2,215
    738
    Aug 11, 2014
    Only problem is he might have one of these in the back yard that has dry skin like you.
    [Moderator Edited Image]
  12. Martaine2005
    Martaine2005
    3,653
    994
    May 12, 2015
    Now that is dry skin!!
    That thing needs E45 or similar...:p
  13. Martaine2005
    Martaine2005
    3,653
    994
    May 12, 2015
    [​IMG]
    Tha fios agaibh likes this.
