MR-16 Questions
Z
z
I have several MR-16 fixtures and need constant color-type bulbs with UV
protection in various beam spreads (all 35 watt).
- Do I always need to get a lensed (cover glass) type to get UV protection,
or do some bulb manufacturers provide UV filtering without?
- Do any of the glass lenses provided with fixtures (Lightolier, in my
case) provide any UV protection?
- If I use an MR-16 lamp with lens, do I still need to use the glass
provided with the fixture?
- Can I use the MRC-16 in place of the MR-16? The MRC-16 appears to have a
convex lens which may not fit in the socket assembly of some fixtures
Thanks.
T
TKM
protection, or do some bulb manufacturers provide UV filtering without?
The "Constant Color" MR-16 types have reduced UV to start with because of
the reflector properties. Any normal fixture cover glass will reduce that
still further.
case) provide any UV protection? Yes.
Little UV gets through the lamp lens; but an external lens -- especially if
it is designed to also filter the UV-A -- will cut any remaining UV to
virtually zero. That kind of filtering is probably required only for
museum-quality lighting.
a convex lens which may not fit in the socket assembly of some fixtures
As you say, it depends upon the fixture design. I use Halo fixtures for
display work and can use either an MR or MRC plus an external lens and
louver if needed.
Terry McGowan
