Motors
Discussion in 'Sensors and Actuators' started by mattdall69, May 20, 2015.
  1. mattdall69
    mattdall69
    3
    May 20, 2015
    Hello everyone...can you help me. I'm a teacher, so straight from the get-go, money is an issue for components.
    I'm building a Line following 'bot with ldrs and transistors. Got everything worked out and built, but I need a small motor with torque to move it (I've built a prototype with solar motors, just to see if electronics work).
    Any suggestions on cheap little powerful motors to do job? A link would be nice.
    Many thanks.
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    Hello Sir :)
    How fast do they have to go, and are you going to use any gearing? What is the working voltage and supply current available. What space do you have?
    Adam
  3. mattdall69
    mattdall69
    3
    May 20, 2015
    Hello there. Its about 200mm x100mm..very light- laser cut acrylic. I have a motor with gearbox, but was hoping to run the wheels straight from motor...I want a slow motor with a bit of strength. A worm gear wont do..or solar.
    It'll run from 4.5 - 9 v.
    I want to keep I small for costs.
    Thank you.
  4. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    An easy option would be to modify some small RC servos. They have fixings for the body and a screw hole for different types of horns, one being circular with holes in them, so you could connect this to a wheel.
    Adam
  5. mattdall69
    mattdall69
    3
    May 20, 2015
    Yeh..im not familiar with servos. Do you have a link for me? Much appreciated.
  6. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    Here is some info about modifying them. It's quite easy. Also a link to a supplier. This will give you an idea of the specs and what they look like. You can then try and find some cheaper ones.
    Adam
    http://www.servoshop.co.uk/
  7. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
  8. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Adam, can these be controlled easily enough without a microcontroller?
    To the OP.
    These line followers, do you have a BillOfMaterials or schematic we can see?
    I've built one of these in school and it used an H-bridge IC and a comparator. Is this the same approach you are taking?
  9. mattdall
    mattdall
    6
    Mar 2, 2015
    Thanks for your help.
  10. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    Your welcome Sir
  11. mattdall
    mattdall
    6
    Mar 2, 2015
    Hi there. No i'm just building a prototype. Using darlington pair and solar motor (Two identical circuits, one for each motor.) I've actually got it working, but i could do with a slower motor with more torque?
