motorola 13301, 13300, 13298, 13299 data
Discussion in 'Electronic Repair' started by N Cook, Mar 2, 2007.
  1. N Cook
    N Cook Guest
    It looks as though I'll have to find equivalents for at least the 13301 and
    13300 , 1969 vintage, from a JBL SA660 amp. One 13301 is leaky.
    Anyone have any data on these early power transistors, TO3 and T066.
    I should be able to determine Hfe and adjust to fit higher gain replacements
  2. Meat Plow
    Meat Plow Guest
    Google motorola 13300 and 13301.
    www.datasheetcatalog.com/motorola/133/ comes up with the
    13300 and 13301 but they are TO220 and replaced by these:
    http://www.datasheetcatalog.com/datasheets_pdf/M/T/P/5/MTP5P25.shtml
    If the cross is correct and it may not be.
    But I assume you've already done this.
  3. N Cook
    N Cook Guest
    The TO66 ones, i'll probably have to settle for 2N4912 and 2N4900
