P
PaPaPeng
I am hijacking the guts from a miniature RC model boat toy ( see
http://www.sharperimage.com/us/en/s...DARGS=/us/en/include/standardheader1.jhtml.13
) to motorize the Revell S-100 Schnellboote that has three
propellers. (see
http://www.modelwarships.com/reviews/ships/dkm/s-boat/s-100-72/72-S-100-p1.htm
The Sharper Image mini-speedster boat is powered by two cellphone type
(I think) minimotors that has forward and reverse rotations controlled
independently from the RC transmitter. This is its steering
mechanism. There is no rudder. I think this is a great solution as a
separate channel for the rudder would involve a servo and its
associated installation complications, especially in a small model
such as the S-100.
The design question is the middle motor.
My idea is to feed each motor's forward signal into an OR gate and use
the output to power the middle minimotor. The mini-speedster's motor
has 3 wires, presumably fwd, rev and common. That way so long as one
side motor runs in forward the middle motor will run. The other
outside motor will be used to steer. If both side motors are stopped
or in reverse, the middle motor won't run.
Is the output of the OR gate enough to power a cellphone minimotor (2
NiCad cells power the everything in the mini-speedster.) Or do I
need to use that output to turn on a switch to a separate power supply
for the middle motor? Will the minimotors' power be drawn off too
much juice in supplying the OR gate's input signal? Any other design
considerations?
propellers. (see
such as the S-100.
considerations?
