motorcycle alarm
Discussion in 'General Electronics Discussion' started by jhayar25, May 3, 2012.
  1. jhayar25
    jhayar25
    47
    Mar 28, 2012
    what is the main most important of the motorcycle alarm to pro long the life span of alarm example 100% watr prof,do you think it must mader from relay switch what section must have when using relay switch...?>pls help thnk you
  2. CocaCola
    CocaCola
    3,635
    4
    Apr 7, 2012
    Not sure what you are asking, are you asking if it's important to waterproof the alarm system? Yes, to a point but that doesn't mean in needs to be encapsulated, under the seat (or other shielded compartment) with most of the other electronics in say a project box will suffice in most cases...
    Not sure what you are asking in regards to the relay...
  3. jhayar25
    jhayar25
    47
    Mar 28, 2012
    motor cycle alarm
    ok tanx....do you think relay is very important in module alarm like motorcycle ex..pink wire FOR SIREN controling y transistor B772 do you think it is the best way to pro long the life of transistor B772 or transistor B772 with Relay i want to pro long the life span of any component in a modlue alarm can any give an idea how,their are many section what section most better to used a relay switch..can any give me an idea..pls help..
