motor schematic
Discussion in 'Electronic Repair' started by Jon, Nov 10, 2012.
  1. Jon
    Jon Guest
  2. Phil Allison
    Phil Allison Guest
    "Jon"
    ** That is certainly how it looks.
    LINE = AC power, active and neutral.
    The moving contact of the 2 speed switch links to one AC conductor while the
    other goes to the white wire, plus the 7.5uF cap.
    ..... Phil
  3. Ken
    Ken Guest
    It appears that this motor is a 220 volt motor. If so, line would seem
    to be two 110 leads out of phase and neutral would not be involved
    except for ground. Would it not?
  4. Phil Allison
    Phil Allison Guest
    "Ken"
    ** The plate says " 208V to 230V PH 1 "
    So there are any number of ways to use it successfully.
    Mr pedant.
    ..... Phil
  5. Jon
    Jon Guest
    This explains it. I understand it now. Thank you everyone for your help.
    Jon
