Motion Sensor and LED's - How to Make Circuit
Discussion in 'Electronic Design' started by Sizz, Mar 5, 2007.
  1. Sizz
    Sizz Guest
    Im having some difficulty trying to make a circuit.
    I want to create a desk lamp which only switches on/off when you wave
    your hand across the sensor.
    I will be using
    4x AAA batteries 1.5v Each 1150mAh
    8 LED 3.6 Forward Volts - 20mAh
    120 ohm Resistors
    Not sure about the sensor and other components..
    Please can someone help me specify the materials and circuit layout.
  2. D from BC
    D from BC Guest
    Maybe try an infrared phototransistor and infrared LED cct for motion
    detection.
    D from BC
  3. Wim Ton
    Wim Ton Guest
    I have seen some clever circuits (probably in EDN design ideas) that used
    the LED's as a photodiode as well
    Wim
  4. Guest
    I would suggest AA cells over AAA cells.
  5. Guest
    cct?
  6. Rich Grise
    Rich Grise Guest
    Circuit.
    Cheers!
    Rich
  7. Rich Grise
    Rich Grise Guest
    Sure, for US$60.00/hr.
    Good Luck!
    Rich
  8. Guest
    I thought that for a second, but ckt is more common, though probably
    less correct.
