Motion Activated Motors
Discussion in 'Sensors and Actuators' started by Noah Abbott, Jan 24, 2017.
  1. Noah Abbott
    Noah Abbott
    4
    Jan 23, 2017
    Hello,
    I am fixing a project right now that is a rube goldberg machine, activated by people walking by. What I want is when someone walks by, it sends a signal to some timer, and then runs the motor that lifts balls up for just one second. So I'm looking for two devices, and I just can't find what I'm looking for. This runs at 120V, and doesn't need varying speeds or anything, it just needs to run for 1 second when a person passes by. I assume that'll take a motion sensing device (preferrably somehting small and hidden like a photoelectric switch) and a timer device.
  2. davenn
    davenn Moderator
    13,765
    1,920
    there are proper PIR ( Passive InfraRed) detectors for this ... used for intruder alarms
  3. Noah Abbott
    Noah Abbott
    4
    Jan 23, 2017
    I suppose I could, but those tend to be large and obvious, not usually hidden, if I'm correct.
  4. Noah Abbott
    Noah Abbott
    4
    Jan 23, 2017
    Also, do you know a device that would then tell the motor to run for 1 second? I know there are physical timer devices that can, but I have no idea how to search for it. I suppose I could also use a mictrocontroller, but it'd be nice to just have a hardware component.
  5. Noah Abbott
    Noah Abbott
    4
    Jan 23, 2017
    Actually a correction on myself, after looking it up I suppose there are some that I could hide under the machine just as well. Is it okay that this is in the front entry way where cold air rages in all the time?
  6. davenn
    davenn Moderator
    13,765
    1,920
    well use some imagination and recase them ;)
    .... you are not going to get anything much smaller than the internal cct board that will do the first part of what you require
  7. davenn
    davenn Moderator
    13,765
    1,920
    a NE 555 timer circuit triggered by the PIR would probably do the trick
    others on here may be able to help with that
  8. davenn
    davenn Moderator
    13,765
    1,920
    probably not a real problem ... they get used for outside home front door light trigger switches all the time
    the main trick is ... DONT point them where the sun will shine on them ... or some other heat source .... heaters etc
  9. Bluejets
    Bluejets
    4,505
    958
    Oct 5, 2014
    Most of the home detectors have "zones" that radiate down and sideways. Result being they detect movement mostly by movement across the zones rather than straight in. They usually have a switch wire out at the voltage of the supply so this could start your timing via a relay or similar. Problem may be that even set on "test" they give a switch output for maybe 5 to 10 seconds. Arduino etc. units may suit better.
  10. KTW
    KTW
    273
    15
    Feb 22, 2015
    Some pir's have adjustable timers built in.
  11. Bluejets
    Bluejets
    4,505
    958
    Oct 5, 2014
    The op wants it to operate for 1 second. Those domestic pir's are difficult to set exact times in minutes let alone seconds. As I pointed out, even on "test" the trip time would be too long. Hence reference to the Arduino unit.
  12. KTW
    KTW
    273
    15
    Feb 22, 2015
    I guess I read 1 second but for some reason I thought it was 1 minute.
    Carry on.
