Hello,
I have a condor laptop (nomad n14) with this mother board: “hannstar j 94v-0 e89382”, which has the fan stopped working, I get the fan off the motherboard and it worked fine, so I tried to measure the voltage that the motherboard is giving to the fan and I found that it is null (0 v), I searched the net and I found that this may be caused due to bios problem, so I removed the battery and the CMOS battery and clicked on the power button about 15 secs, and then putted the battery again, when I enter F2 options I find that the time has changed (I suppose that the bios is reseted, but the laptop did not take too much time to boot up, I red that it should take some time to boot up after BIOS reset, and the options in the F2 menu does not have bios reset option), but the fan is still not working, I tried to power the fan from the USB output, when I put both 5v and gnd from USB port it does not work, but when I put just the 5V from the USB port and the gnd from the normal fan motherboard connectors the fan works, but the Hard disk stops.
I hope that you can help.
