Motherboard caps
A
Andy Cuffe
The CPU is not getting warm.
It sounds like it's beyond repair then. If it's run too long with bad
caps it will damage other parts on the motherboard. Unless it's
something obvious like an overheated resistor, there's no practical
way to fix it.
Andy Cuffe
[email protected] <-- Use this email address first
[email protected]
C
CJT
way to fix it.
Andy Cuffe
[email protected]
The first thing to check is that the capacitor replacement was done
properly -- polarities were honored, no solder bridges were created
where they didn't belong, the board wasn't shorted when it was put
back in the case, etc.
Then debug as if it were a new motherboard. Start with nothing more
than is necessary installed (e.g. just a video card and some memory).
Since it was out of the case, something else may have been disturbed.
James Sweet
way to fix it.
Andy Cuffe
There's still hope, check the voltage regulator sections, if you look up a
datasheet of the regulator chip you should be able to find a reference
schematic which will likely be very close to what's on the board. Not really
cost effective when you factor in time but if you like fixing things it
could be fun.
Similar threads
A
Replies
12
Views
2K
Ross Herbert
R
W
Replies
10
Views
1K
What The
W
P
Replies
4
Views
2K
Gerard Bok
G
