most appropriate high speed interface
Discussion in 'Electronic Basics' started by Jan van Timpeln, Jan 11, 2006.
  1. Hello community,
    I am a student of electrical engineering and in the course of a laboratory I
    am currently designing a serdes chip and looking for an adequate interface
    for the I/Os.
    Power dissipation an chip space are the most relevant aspects. What I do is
    a 10Gbit/s to 1 Gbit/s deserializing. On the input I am using LVDS signals,
    so what would be an appropriate signalling on the output for 1Gbit/s
    signals? Is it possible to transmit 1 Gbit/s single ended or do I need to
    use differential signalling? Unfortunately that means double the pad number
    and thus double chip space, but chip space is expensive.
    Because the supply budget is limited I want a minimum on power dissipated at
    the output buffers. What transmission standard would be advisable in that
    respect?
    Thank you very much in advance
    Jan
  2. Joseph2k
    Joseph2k Guest
    If the design were for the most common 9.6 GB/s system then 8 to 1 is the
    correct ratio. Or 4 to 1 or 16 to 1. At 16 to 1 single ended becomes
    reasonable.
    bad choice of follow up groups, this not a cad issue currently.
