Mosquito killer
Discussion in 'Electronic Design' started by George Jefferson, Apr 8, 2010.
  1. Is there a chemical deadly to mosquitos that is lighter than air?
    I was thinking about making an device that could kill them. I guess it's
    probably no better than a bug zapper.
    The idea is that since they, supposedly, are attracted to CO2, to make a
    bucket with an inverted code with a hole at the bottom. The mosquitos find
    there way to the hole which is releasing CO2 then go instead. The gas is
    trapped at the top of the inverted cone which should kill them.
    They probably already make this sorta thing but it seems like it would be
    something rather easy and very cheap and one could place several of them
    throughout the property which is more efficient than just one or two
    zappers. The gas would allow one to increase the opening hole size which
    might be more effective.
    Seems they already have many of these types of devices. Most don't use the
    gas. Probably not necessary. Do these devices work well? I can get a small
    cylinder of CO2 and rig something up quite easily if it's worth doing.
  2. Martin Brown
    Martin Brown Guest
    HF (too reactive), NH3 (too soluble) or HCN but only by a tiny amount.
    It is also deadly to most other forms of life. Expect a visit from
    homeland insecurity and free accommodation in some hell hole if you try
    to buy it.
    Pheromone bait will work considerably better. Electric traps make a
    satisfying frying noise when the creature meets its end.
    There are plenty of reviews of existing designs online.
    Regards,
    Martin Brown
  3. Helium. It's not poisonous, but it displaces air, so that anything
    needing oxygen would suffocate. It does, of course, require the
    concentration to be kept really high inside your trap.
  4. amdx
    amdx Guest
    I like the inverted cone idea, I'm in Fl. and the local mosquito control
    uses dry ice
    (solid CO2) in their traps to attract the mosquitos.
    The density of air is 1.20 kg/m^3 and CO2 is 1.8 kg/m^3 so you the trap
    would
    stay full of CO2, just allow enough CO2 flow to get some gas into the local
    environment
    to attract the mosquitos. Once they go in, there would be no oxygen and they
    would die.
    It seems from other products that the lights also attract the mosquitos, so
    adding a light
    around the top may increase the kill rate.
    I think you'll need to experiment to optimize cone depth and angle. Maybe a
    light outside
    to get them to the trap and a light inside at the bottom of the hole to get
    them inside.
    (B)
    | \ / | (B) is a mosquito attracting light.
    | (B) |
  5. pimpom
    pimpom Guest
    We have Chinese-made 'mosquito fryers' here. They are shaped like
    a tennis racket, use a rechargable battery and produce a really
    satisfying crackle when you swipe a mosquito. It comes with a
    flashlight on the handle, pointing sideways in the direction of a
    swipe and costs about US $4.
  6. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40122
    I think I've seen them for $1.99.
    The fancy mosquito killers use propane:
    http://www.amazon.com/Koolatron-Guardian-Shield-Propane-Mosquito/dp/B001P6E2UC
  7. http://www.physorg.com/news156423566.html
  8. D Yuniskis
    D Yuniskis Guest
    Commercially available units tend to burn propane to form the gas.
    We had thought of buying one or two for use in the back yard
    until realizing the horrendous waste of propane involved
    (why not just put an outdoor grill out there and set the
    gas to the "leak" setting! :> )
    It is very dry here. So, eliminating standing water does
    wonders for controlling the mosquito population. (OTOH,
    if you leave a bucket of water outside, it is amazing to see
    how quickly the larvae develop! look like little *eels*
    swimming in the bucket!)
    Also, being indoors at "mosquito time" helps a lot.
    The little ladies like it relatively cool when "hunting".
    At scout camp, we took the "manly" approach to controlling
    the pests: a 4G pressure vessel mounted to the hood of
    an army surplus (of course) Jeep spraying pesticide onto
    the hot manifold (i.e. a 1.5 ton "fogger"). I wonder how
    many of us will end up with lung cancer or some other
    malady attributable to this high exposure to pesticides??
    <frown>
    (of course, the approach was entirely ineffective. You
    need *tons* of juice to cover hundreds of wooded acres :< )
