mosfets in critical condition
Discussion in 'Electronic Basics' started by [email protected], Oct 10, 2008.
  1. Guest
    Let me guess... it's NOT normal for a mosfet to register < 40 ohms
    between D and S with no gate voltage applied...
    correct?
    Michael
  2. If the gate is floating it might? Or if it's depletion mode?
  3. Guest
    I've got IRF530 and an IRLZ34N mosfets.
    I noticed something was up when my power supply's current limiting
    circuitry deactivated the power supply.
    Debugging: one at a time, I connected the drain to a 12V light bulb,
    and tapped the gate with +12V. The light bulb turned on, and STAYED
    on even with the gate voltage removed. That's not supposed to happen,
    is it?
    At first I thought I had a bum IRF530, burned out from previous
    experiments, so I tried my IRLZ34... same thing...
    A TIP31A behaves as I'd expect it to though... turns on, then off when
    I remove voltage from the base...
    Transistor triage...
    Michael
  4. Guest
    Oh ok! I'll breadboard a test circuit that grounds the gate, and see
    if that fixes things...
    M
  5. Eeyore
    Eeyore Guest
    Applied ? Sure there's not some charge on there already.
    Now try SHORTING the gate to the source.
    Graham
  6. Guest
    Ok, will do when I get home from work.
    Mosfets in critical but stable condition...
    How's the girl from the pub doing?
    M
  7. Eeyore
    Eeyore Guest
    Will post to the original thread.
    Graham
