MOSFET to replace a relay
Discussion in 'General Electronics Discussion' started by Rajinder, Sep 12, 2016.
  1. Rajinder
    Rajinder
    531
    9
    Jan 30, 2016
    I need to replace a relay with a MOSFET. The relays have very low contact rating is 30milli ohm. I need to switch low value resistors typically 0.2R.
    I am measuring currents in the 2uA range, so can't afford that to be affected.
    The relays are controlled from a PIC micro. Is there any MOSFET I could use?
    Best regards,
    Raj
  2. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    Look in the IR IRL series, the IRLZ44S for e.g. is 28milli ohm.
    logic gate.
    Max
  3. (*steve*)
    25,490
    2,831
    If the voltage is low, there are many options. Some as low as single digit milliohms.
    For such low currents I cant see the resistance being a huge issue. Are you really concerned with nanovolt differences in voltage?
