MOSFET switch for Battery Discharge circuit
Discussion in 'Power Electronics' started by triggerman911, Jul 6, 2015.
  1. triggerman911
    triggerman911
    Jul 6, 2015
    Am building a circuit designed to discharge a NiMH 12 v battery. The safe cutoff for the battery is 10 volts, my question is:
    Should I use a Mosfet as the switch on switch off component, and if so, does anyone know of a Mosfet type that will switch off at 10 volts?
    Trigger
  2. Harald Kapp
    12,310
    2,928
    The circuit idea per se is not bad. The MOSFET will turn off when Vgs < Vth (Vgs=Gate-source voltage, Vth=threshold voltage). You can adjust Vgs by tweaking the resistors R1 and R2.
    Unfortunately it is not as simple as your schematic for several reasons:
    • Vth of any MOSFET has comparatively high tolerances (look in any datasheet). Therefore the circuit would have to be adjusted for the actual MOSFET being used.
    • Vth is temperature dependent. You'd have to compensate this.
    • The MOSFET will not turn on/off sharply. Rather it will become less conductive with the voltage dropping towards Vth.
    • As soon as the MOSFET turns off, the battery will recover, voltage will rise and the MOSFET will turn on again.
    A reliable circuit will use a comparator circuit with Schmitt-Trigger characteristic (ask your favorite search engine) to detect the "low voltage" condition and control the gate voltage to a MOSFET to cleanly turn-off the load. The Schmitt-Trigger characteristic will prevent the circuit from turning on again when the battery recovers when the load is turned off.
    hevans1944 and Arouse1973 like this.
