Q
+Q__
Hi everybody,
I'm researching components for a circuit I'm designing, and I need to
clear up some confusion over some advise I've recently received.
I'm using an OOPic 2+ as a control for solenoid coils. I plan on using
30 of the IO Lines from the PIC to switch them on and off
individually.
The problem is, the OOPic uses +5V. My solenoids are rated for +24VDC.
I was advised to use the IO Lines on the OOPic to drive their
corresponding MOSFETs and thereby power/switch the solenoids on and
off. I was specifically advised to use the DS current of my mosfets to
send power to the live wires of the coils.
My question is:
How can I adequately power solenoids rated for +24VDC with a circuit
that possesses and can only handle +5V? What type or part number would
be the right MOSFET to use?
Thanks for the help,
Q
individually.
My question is:
Q
