MOSFET pull down in linear region
Discussion in 'General Electronics Discussion' started by matt111111, Jan 17, 2018.
  1. matt111111
    matt111111
    4
    Nov 26, 2014
    I have a current sense IC powered directly from a battery. I want the current sense IC to be in the shutdown state when the 3.3V power supply is disabled.
    I have added a dual N channel MOSFET circuit (see attachments) to achieve a pull down on the shut down pin (active low and internally pulled high) when the
    3.3V supply is not present. The circuit seems to work in LTspice but I am concerned about one of the MOSFETS operating in the linear region. (VDS < VGS - VT)
    Is it safe to operate the MOSFET in this configuration or is there anything I'm missing that is considered bad design?
      File size:
      18.6 KB
      101
      File size:
      20.4 KB
      107
  2. Alec_t
    Alec_t
    2,762
    736
    Jul 7, 2015
    Vgs = 30V would kill most fets!
    Unless the 3.3V drops extremely slowly the linear state would be brief. With such high resistor values there will be only miniscule power dissipated in either fet.
  3. Harald Kapp
    9,669
    2,020
    With R2 = 1 MΩ a suitable zener diode from the gate of M1 to gnd will provide protection.
    Tha fios agaibh likes this.
