P
Peter Gottlieb
Hi all...
I'm building an electric go-cart for the kids using a 24 Volt motor. I have
an H bridge with each leg being 2 paralleled 8 milohm 50 amp MOSFETs. Each
half bridge is driven by a Linear Technology driver which has lockout to
prevent shoot-through.
After I built it, I decided to test with a 75 Watt 24 Volt bulb and a
current limiting power supply. I plugged my bridge assembly into a test set
I built which sends either a "brake" (both lower sets of mosfets on),
"forward" (one upper and one lower mosfet sets on) or "reverse" (opposite
sets of mosfets on) command.
When I give the forward or reverse command, the bulb lights (opposite cmd
gives reversed polarity as expected) but the LT chip starts heating up big
time. I see that the drive starts going down after a few seconds until some
mosfets are in the linear region - not good (although no problem with just
the bulb, I have them on a big heat sink).
Anyone have any idea what's happening? There aren't that many inputs to
that chip and they all look proper, power is clean, nothing going on on the
ground.
I tried hooking up the motor and it surged like crazy with the power supply
showing overvoltage, then current limit (at 25 amps) all over the place.
That is difficult to probe due to the currents and my not wanting to let it
do that for too long. The mosfets didn't even get mildly warm, but again,
the LT chip started getting hot rapidly. Unplugging the LT chip allowed me
to manually drive the mosfets and they seem just fine with nothing but the
usual capacitive gate load. A 400 MHz scope shows no oscillations anywhere.
The LT chip is on the H bridge assembly and the inputs are isolated.
It's gotta be something simple, but what?
ground.
