MOSFET, JFET
Discussion in 'Electronic Design' started by john, May 23, 2007.
  1. john
    john Guest
    I am looking for a FET with following specs.
    1. Vgs = 1.2 VOLTS (max)
    2. Vds = between 20 to 30volts
    3. Id = 60mA
    Please advice
    John
  2. Tim Wescott
    Tim Wescott Guest
    My advise is to make your question clear.
    If it's a MOSFET or a JFET, say "I'm trying to figure out if this data
    sheet is for a MOSFET or a JFET".
    If you had, I would say probably not, because they're letting you have a
    positive Vgs, which would forward bias the gate in a JFET.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  3. Indeed. Perhaps he wants a small low-gate-voltage MOSFET,
    like a Supertex TN0104N3 (in a TO-92 pkg) or TN0604, or ...
    Mouser stocks them.
  4. D from BC
    D from BC Guest
    IIRC I saw a logic level mosfet with Vgs spec'd as low as 0.85V.
    (Neglecting that freaky chip with Vgs=0)
    I can't recall the Id @ Vgs 0.85V.
    And I can't recall the part number..but I saw it a few days ago on
    Digikey.
    D from BC
  5. Phil Allison
    Phil Allison Guest
  6. Phil Allison
    Phil Allison Guest
