E
Ed
Hi All possibly quite a simple question but I would like some advice.
I have been looking at ways to use an IRFZ44N as a solid state 'switch'
to switch on and of the positive supply of a 12 to 24 volt supply. As
far as current requirements go the IRFZ44 is ideal, but I'm sturggling
to find a good way to do this.
To fill in more info its for a high current serial bus of 3 wires,
12-30v Ground and Data.
I need to beable to control the Data and Supply lines from a 5 volt
logic level as simply and as ruggidly as possible, yet both must be
capable of high currents, and minimal on resistance. I looked at using a
P channel fet, such as the IRF5210 thinking this may be a solution, but
I think I am going totally the wrong way.
Any suggestions would be a MASSIVE help.
Ed
Ed
