I suppose it's more accurate to say "stuck closed", not an engineer here. I'm using an ATTiny chip to drive an n-channel mosfet which in turn is controlling a motor. Here's a pic of the schematic.
This circuit works exactly as designed if I use a motor that draws about half an amp. Once I use the motor I actually like (which draws about 1.5-2 amps) it's like the mosfet gets stuck open, and the motor never shuts off. The mosfet in question is this one: https://www.sparkfun.com/products/10213
I've tried heat sinking the mosfet, which changes nothing. What am I missing? I built this part of the circuit using the tutorial found here:
http://bildr.org/2012/03/rfp30n06le-arduino/
Also, this is an older schematic that used an 8V reg on the motor - I've since moved on to a different motor and have removed the regulator altogether, so that isn't it.
