K
[email protected]
I have a problem where I need to measure the gate charge of an NMOS
device which is to be used as the control MOSFET in a buck regulator.
What is the simplest way to do this? I did a search in this group but
though some answers come close, I cant find the exact method.
Another question regarding the same - Since the MOSFETs are usually
driven by a Voltage source + resistor (and not a constant current),
what is the utility of the gate charge graph that is usually given on a
power MOSFET datasheet. ie. how do you determine the voltage source and
resistor values if you are given that the NMOS has to turn on in a
given time and you are given the gate charge graph?
Kais
Kais
