N
Nathan Hunsperger
Hello,
I've noticed a very peculiar problem with a MOSFET in one of my
designs. For reference, I am using an IRL3715, and I should be
well within the rated voltage, current, and switching times. I
have the source connected to GND, the gate to my uC (with a large
value pull-down), and the drain goes to a connector so I can sink
current through a bunch of LEDs.
Now onto the weird part. When the gate is at 5V, I show 0V difference
between GND and the connector, and 12V difference between 12V and
the connector. This tells me that the MOSFET is switched on like it
should be.
However, when the gate is grounded, I show 0V difference between
GND and the connector, but a 4.5V difference between 12V and the
connector. While the 0V between GND and the connector can be
indicative of an open (which should be the case), where exactly is
this 4.5V comming from? Changing the polarization of my multimeter
reads -4.5V. Placing an LED+resistor from 12V to the connector
does not light up, so the 4.5V is extremeley weak.
Additionally, my 5V rail is nowhere near this area of the PCB, and
I have 3 other channels that opperate as I would expect (0V between
the connector independent of which power supply I measure against).
Obviously, this MOSFET is damaged, and I will be replacing it, but
I'm curious as to why this happened. All assembly took place on
an anti-static mat, with me carefully grounded to it. Admitantly
though, I know I touched the drain several times while not grounded,
but I would have touched all the channel's drains checking for heat.
And, from my understanding, it is only supopsed to be the gate that
is extremely sensitive to ESD.
And, on a side note, why did component MFGs attach the heat tabs
of TO220s to the drain? I know you can get full-packs, and have
isolation, but why was this done in the first place? Drain is
always going to be hot with respect to GND, and I can't think of
any reason to have your heatsinks at a different potential than
your conducting chassis...
Looking forward to an explanation,
Nathan
should be.
Nathan
