More mechanical than Electrical Question...
Discussion in 'Electronic Basics' started by Dannyboyy, Apr 28, 2005.
  1. Dannyboyy
    Dannyboyy Guest
    Hi - I want to mount a portable DVD player to the roof of the minivan so if
    anyone has experience dealing with a later model roof liner please lend me
    your thoughts -
    I'm thinking something temporary that could be screwed into female
    connections that penetrate the nterior roof liner. The connections would
    have to be
    anchored somehow and that is where I am stuck. Any ideas?
  2. Lord Garth
    Lord Garth Guest
    How about removing the dome light and utilizing its mount?
  3. Dannyboyy
    Dannyboyy Guest
    That's a really good idea. Since the DVD player would be temporary I do not
    mind stringing up the DC power and earphone output line though. And since
    it is a newer van I am trying to do something low impact - It would be
    nice if the dome light was not switched then I could pull power off of that
    without turning all of the interior lights on.
  4. Lord Garth
    Lord Garth Guest
    I'll bet you can snake a power cable through the 'B' pillar (the column
    behind the
    driver and in front of the rear seats) to find power at the nearest lighter
    socket or
    failing that, go under the door rail and into the kick panel then on to the
    fuse block.
  5. The dome light probably is hot all the time, many are. The door jamb
    switch usually completes the circuit by switching the return wire to
    ground. You just need to find your own ground for the CD player, and
    that shouldn't be too hard.
