More length in wire
Discussion in 'General Electronics Discussion' started by Life24, Sep 11, 2015.
  1. Life24
    Life24
    6
    Sep 10, 2015
    Hello,
    When we increase length of wire , we have voltage drop. why? o_O
  2. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    because simply put, a wire has resistance. over long lengths its noticeable. voltage and current can be affected.
  3. Ratch
    Ratch
    1,094
    335
    Mar 10, 2013
    You should be more specific. For instance, if I apply 12 volts across 1200 feet of wire, then there will be a 12 volt drop across the total 1200 feet of wire. Now, if I increase the length of wire to 2400 feet, then there still will be a 12 volt drop across the total wire. Is that what you wanted to know?
    Ratch
  4. Harald Kapp
    11,978
    2,806
    I doubt it. Donkey's answer is more to the point. Voltage drop along a length of wire is the product of the current through this wire and the resistance of the wire: V=I*R.
    Therefore voltage drop increases if the resistance increases aka longer wire (of the same thickness, of course) or more current (higher load).
    Essentialy the wire and the load form a resistive voltage divider
  5. davenn
    davenn Moderator
    13,940
    1,984
    you and Donkey may well be right
    But I suggest it seems ( as Ratch hinted at) that the Op doesn't really understand the meaning of voltage drop
    considering how vague the question was
  6. Harald Kapp
    11,978
    2,806
    Right, especially in view of his other thread which I just came across.
