More current to stepper motor
Discussion in 'Sensors and Actuators' started by rj23, Jul 20, 2020.
  1. rj23
    rj23
    7
    Jul 20, 2020
    Hi all,
    Bit of an odd one.
    I have an aftermarket car ecu that has a 4 wire stepper motor attached to it.
    Unfortunately, the ecu is current limiting to 1 amp.
    The motor needs 1.85 amps (6.5 ohm motor, 12volts).
    It therefore needs a bigger current supply (no position feedback needed).
    Is anything available (make or otherwise) where the 4 inputs can be connected, and the higher current can be output?
    thanks
    Rod
    siemthanh5 likes this.
  2. Bluejets
    Bluejets
    4,984
    1,045
    Oct 5, 2014
    Show a schematic of your installation.
  3. rj23
    rj23
    7
    Jul 20, 2020
  4. rj23
    rj23
    7
    Jul 20, 2020
  5. Bluejets
    Bluejets
    4,984
    1,045
    Oct 5, 2014
    Block diagrams do not help much.
    If you can gain access to the step direction signals ( which I doubt) then you could use just about any driver.
    Why you need to drive at a higher current is a mystery though.
  6. rj23
    rj23
    7
    Jul 20, 2020
    The motor and the ECU are from different automotive applications. The rated supply of the ecu is insufficient to drive the motor in the other assembly.
  7. Alec_t
    Alec_t
    2,970
    805
    Jul 7, 2015
    You could use the ecu to control power MOSFETs to switch the stepper motor. The devil will be in the details.
  8. rj23
    rj23
    7
    Jul 20, 2020
    I like your thinking.
  9. bertus
    bertus Moderator
    2,024
    757
    Nov 8, 2019
    Hello,
    @01sporty , The L298 is not going to work.
    It can deliver 2 A per channel, but total device current is 4 A.
    Bertus
  10. Minder
    Minder
    3,102
    664
    Apr 24, 2015
    You also require some means of ensuring the winding current is a constant 1.85amps at all speeds.
    M..
